RumorConsumer
Aug 05, 2019Tutor
Netgear switch disappears from Meraki
I have a GS310TP that is connected directly to my Meraki MX65 SD-WAN device. It was showing up in the client list on the Meraki dashboard as having claimed an IP, I was able to log in, all that jazz. ...
- Aug 06, 2019
Adding an NTP server to the config does it!
RumorConsumer
Aug 06, 2019Tutor
schumaku
Aug 06, 2019Guru - Experienced User
RumorConsumer wrote:Adding an NTP server to the config does it!
Cool idea - this is causing the IP traffic will help the Meraki to recognize it as a system present and active on the network.
