momo_01
Apr 26, 2022Follower
NETGEAR Switch S3300-PoE+
Hi Dear Netgear Community. "If a loop is detected behind a port, this port will be deactivated. After a certain time, the port is automatically reactivated." Is this feature possible on my ...
DaneA
May 02, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
Is this feature possible on my NETGEAR Switch S3300-PoE+ (28 Ports)?
It seems that this somehow refers to STP (Spanning Tree Protocol). STP is supported on the S3300 series switches. To learn more about STP, kindly check the article below:
What is SpanningTree Protocol (STP) and how does it work with my managed switch?
Second thing: How can I configure the POE the following:
PoE was configured in such a way that the access points remain
in operation if the PoE budget is exceeded
and the other devices in the network deactivate the one with the highest consumption first.
I believe this should automatically work on the S3300 series switch. Kindly read about PoE Classes here.
DaneA
NETGEAR Community Team
