Brad0va's avatar
Brad0va
Follower
Oct 26, 2020
Netgear XS716T not negotiating 100/half speeds
We are having an issue with our XS716T auto negotiating 100/half speeds. When we connect a 1G or 10G device to the switch it immediately connects. We have a device that can only do 100/half that we need to connect to this XS716T at different times. I can go in and manually set the speed on one of the ports, the device will connect. I will set the speed on the port back to auto/auto and the device will connect. If the switch power cycles, the device will not connect unless I go through the steps above.
Any help is appreciated.
  • Retired_Member's avatar
    Retired_Member
    Oct 27, 2020
    Hi Brad0va
    Welcome to Community!
    Yes, it just work as design. 100M F/H not support auto-negotiate, you need to set port speed to 100M half by Web GUI. No need change back to Auto mode. Then it will work fine even after rebooting.
    Hope it helps!
    Regards;
    Eric
1 Reply
    Retired_Member
    Hi Brad0va
    Hope it helps!
    Regards;
    Eric
ProSupport for Business
