CKopp
Jul 09, 2026Luminary
Network switch selection for VLAN design
I currently have an unmanaged network consisting of a 24 port switch, 3 - 8 port switches, a Netgear RS series router and a cable company supplied modem. Several IOT devices reside on this network, ...
Jul 10, 2026Guru - Experienced User
CKopp wrote:can I get away with replacing the 8 port Port switch at B and put a new 4 port switch between the IOT devices and my main 24 port switch.
FWIW, you haven't said how the streaming devices are connected. Are they also connected only to switch A and B?
Another aspect is how much isolation you want for the IoT devices. You won't be able to isolate them from the wifi network with this arrangement, since the RS routers don't have the VLAN features you need. I am assuming you want that isolation.
You could connect a wired router (or L2/L3 switch with routing functions) to the modem, and then use the RS router as an AP. As far as Netgear kit goes, the GS728 series switches have routing functions built in, so you could potentially connect one of those to the modem. Ideally this would replace switch A, though that depends on whether wiring allows that. Check the manual to make sure it has the routing functions you want.
Of course, one of Netgear's fully managed switches would also work as an edge router.
Is the modem actually a gateway (perhaps in bridge mode)? If it is, you could use the gateway as the edge router (turning off the wifi), and continue to use the RS router in router mode. Then use switches connected to the gateway for the wired IoT devices. These could be unmanaged switches, since the NAT in the RS router would prevent the IoT devices from reaching the RS router network. The RS-connected devices could still reach the IoT devices. The downside here is that you'd have a double-NAT configuration. This is managable, though a bit more complicated if you do port forwarding.
The third option is to get a new small wired router with full VLAN support, and use the RS router as an AP. Unfortunately, Netgear doesn't sell one, so you'd need to use another vendor. As far as switches go, if you have only IoT devices connected to switch B, you'd be able to use connect it to the wired router, and set up the router LAN port as an untagged VLAN. You could also get a small smart switch to connect the IoT devices currently on switch A to the wired router (also connecting that to existing switch A). The GS305E or GS308E switch would work for that.
- impostorJul 30, 2026Tutor
If your main goal is just to isolate your IoT devices from the rest of your network, you probably don't need to replace every switch right away.
I'd prioritize replacing the switches that actually need to carry multiple VLANs (trunk links). Any switch that's only serving devices from a single VLAN can stay unmanaged, as long as everything connected to it belongs to that same network segment. The important part is that the links between your router and the managed switches can carry the VLAN tags correctly.
The GS3xx Easy Smart switches should be fine for a straightforward home setup with a few VLANs. They're not as feature-rich as fully managed models, but for creating separate IoT, LAN, and maybe a guest/streaming VLAN, they generally do the job without being overly complicated to configure.
One thing I'd also think about is whether your Netgear RS router supports the VLAN setup you want (inter-VLAN routing, DHCP per VLAN, firewall rules, etc.). In my experience, the router's VLAN capabilities tend to be the limiting factor more often than the switches themselves.
Do you know which exact RS model you have? That would make it easier to say whether your current plan will work as expected.
- StephenBJul 30, 2026Guru - Experienced User
That is clearly the case here.
- impostorJul 31, 2026Tutor
Exactly. In that case, I'd check the router's VLAN capabilities first before changing the switches. That should save you from replacing hardware unnecessarily.
