BretD
Jun 25, 2019Administrator
New 10-Port PoE+ Switch with Cloud Management Option GS110TPP
GS110TPP is a 10-Port Gigabit PoE+ Ethernet Smart Managed Pro Switch with 2 non-PoE copper ports and optional remote Cloud Management.
The new NETGEAR GS110TPP provides higher PoE bu...
- Jun 27, 2019
Let us know in the comments what you plan to power with this new PoE+ Switch!
BretD
Jun 27, 2019Administrator
schumaku
Jun 28, 2019Guru - Experienced User
No plans yet, but missing a GS110TPP-like Smart Managed Pro model with two SFP+ (yes 10G) or with two 10GBase-T (or MultiGig) uplink ports, similar to the Smart Managed Plus GS110EMX, for some bandwidth hungry PoE+ applications where a LAG of two GbE ports can't cover the bandwidth requirements. One example might be the feed of mutiple GS105PE or GS108T for example.
