CarMar
Sep 18, 2020Aspirant
GS110TPP QoS managed and EEE managed option
Hi I'm considering the purchase of Netgear GS110TPP switch, for use with Dante audio network.
I would like to know if through the QoS management is possible to manage the DSCP and if the EEE (energy efficient ethernet) can be completely disabled on all ports.
thank you all
CarMar wrote:Hi I'm considering the purchase of Netgear GS110TPP switch, for use with Dante audio network.
The preferred solution for AV switching (eg. Dante) networks would be using the M4250 NETGEAR AV Line Switches for 1Gb ProAV Installations now. The similar spec'ed M4250-10G2F-PoE+ is already available in the market.
CarMar wrote:... Netgear GS110TPP switch ... I would like to know if through the QoS management is possible to manage the DSCP and if the EEE (energy efficient ethernet) can be completely disabled on all ports.
8-Port Gigabit (PoE+) Ethernet Smart Managed Pro Switch with (2 SFP Ports and) Cloud Management Models GS108Tv3, GS110TPv3, and GS110TPP User Manual
p.93 ff. Configure green Ethernet settings - Green Ethernet, EEE, ...p.270 ff. Manage the Class of Service - QoS Policies and DSCP
- CarMarAspirant
thanks Schumaku, you are a real guru !!
M4250 would be a nice car, but for me I think it's a bit too expensive and oversized.
I think I will take GS110TPP, from the ref you gave I think that it is suitable for working with Dante.
Thanks again!!
