Pudgemeister
Feb 19, 2023Aspirant
Newbie Here - Struggling With VLAN basics
Hi all
I am giving up on the search engine struggle as it's clear it's my understanding that's the issue.
I am running an establishment in which there is public WiFi, and two private WiFi's. On the private WiFi's, there are multiple castable devices (chromecast, google nest mini, etc.).
The end goal of this is to prevent users on the public WiFi from being able to cast to the castable devices (and hide them altogether if possible).
I am aware that there may be other settings that can prevent this etc. but I am in need, for future use, of how to prevent communication between the Public WiFi users, and the devices on the Private WiFi's.
This is currently how things are set up:
Internet <---> BT Business Hub 2 <---> Port 1 - GS324T - Port 2 <---> Public WiFi AP
- Port 3 <---> Private WiFi AP 1
- Port 4 <---> Private WiFi AP 2
Also - by default - all devices are part of VLAN 1 & all untagged (which I'm struggling to understand completely).
Will VLAN's work here? Is there a way to prevent the communication between Public & Private WiFi's without either losing connection to the internet?
Please can explanations be kept...in a way that a newbie would understand? I am a heavy web developer professional of many years, but have never dipped into networking until now.
Thanks for reading.
The idea new network admin need to learn is that an access point does map any SSID - wireless name - does not create a segregation to different network. Nice idea having different names on air however.
Trouble is almost all consumer routers for home or even some offered explicitly for small businesses allow only one network, one broadcast domain, one IP subnet, and one VLAN only.
Keep in mind that such an add-on router or mesh system like a Orbi Business https://www.netgear.com/business/wifi/mesh/ does allow adding multiple network, VLANs, IP subnets, ... keep the current router LAN as an intermediate network is retained..
- PudgemeisterAspirant
Hi
Thank you for the reply. This was very helpful.
I wonder. Would port/interface based ACL blocking work to block signals from one port to another?
