LW100
Jan 04, 2025Aspirant
Newbie to VLANs - GS308Ev4
All Before I get into any detail around what I want to achieve long term, I have a very basic question.... please bear with, as first time I am trying to setup a VLAN... having looked at many sit...
NetworkNeb
Jan 10, 2025Aspirant
Hello, I'm also a networking Newb that has struggled to understand VLAN's and Subnetting. So, out of my probably 50 hours of trying figure out the nature of VLANS and sub-netting with my first home lab is this.
1. Level 3 switches can VLAN route. I have GS308Ev4, a level 2 switch. This can read and push the tags to the correct port, but can not official tag the data.
2. You need a Level 3 switch in order to VLAN route or a router to VLAN route. They should also be able to establish inter vlan communications if set up with the firewall.
3. I despise VLANS.
4. I'm still on the journey of learning this. So, if another post comes along please listen to them. I just wanted to save you some frustration if possible.
5. If you have an ISP router that doesn't support Vlans or sub-netting, you can install opnsense as a router on as a virtual machine. However, I have not been able to configure the network correctly with a proxmox server running all VM's and the OPNsense router software. Keep in mind of double NATTING.... Due to sever anger that is only comparable to working on a car in the winter, or stubbing your toe on the corner of your desk that spills water on your computer. I have found that double Natting ISP Router > To OPNSense > Vlans is also a pickle to set up without proper equipment. My ISP router offers bridge mode to push the data to the OPNsense router, this takes out my wifi as my server is pieced together like Frankenstein's monster and have no wifi output on my server.
Long story short:
You need to invest in a new router or level 3 vlan switch to do what you want, or order a cheap PC from ebay and install opnsense with a NIC. Again, please keep in mind I am at the same level as you or dang near it. Everything just clicked about needing to have an official dedicated router and/or need a level 3 vlan capable switch. Hence is why I'm here..... I just googled if GS308Ev4 is a level 2 or level 3 switch.............Goodluck, happy networking, and I hope this saved some rage as I need someone else to balance out mine.
Last thoughts:
I'm also attempting the port based approach on GS308Ev4. I have no idea how well this will protect and isolate the networks as they are on the same sub-net. I'm attempting to establish a lot of isolating firewalls between each bridge and have 3 Ethernet cables for 3 virtual bridges. This will not be very secure if I exposed VM 104 to the internet but keep my truenas vm on the same network.
