ctrl_alt_delete
Sep 29, 2023Aspirant
Old Switches vs Newer
I have: 2 x GS108Tv2 1 x GS724Tv3 1 x GS105v4 I have Synology Routers and Mesh devices. WiFi and Wired is used across the house although WiFi does struggle in some areas so we wire wher...
microchip8
Sep 29, 2023Master
A new(er) switch is not going to solve your problems. You'll have to rethink how and where you connect your net devices that make up your network. Some form of QoS can be used that prioritizes certain streams
- ctrl_alt_deleteSep 29, 2023Aspirant
What do you recommend I do?
