JoeM845
Sep 21, 2023Luminary
RBR50: Update firmware from 2.7.4.24 not finding newer firmware
RBR50's Menu item "Advanced -> Administration -> Firmware update" responds with "No new firmware version available" for both the RBR50 and the RBS50. I expected it to find 2.7.5.4, ask for an OK, and update the firmware on both devices.
Is my expectation correct?
Is there any situation/configuration where this is a correct response from the RBR50?
If the RBR50's routines do not work, is there a safe way to update the firmware?
Thanks,
Joe
RBK50, fw 2.7.4.24, Windows 10, Edge
Hello JoeM845 ,
Welcome to the NETGEAR Community!
At this time the most current firmware for the RBK50 systems is an optional update. If you would like to update this firmware please update your firmware manually. Please ensure to update the attached satellites first then update the router last.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#downloadFor step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comBest,
Kevin
Community Team
- JoeM845Luminary
Thanks, but since this fw version was released in February, I expect that it is as "generally available" as it is going to get.
So true. This one of the most frustrating aspects of Netgear product support. One would think that firmware released in February that includes "bug fixes" and "addresses security vulnerabilities" would be "ready for prime time" by September.
It could be as simple as the person who was tasked to move the firmware status to "searchable" has left the company or been reassigned to another role. The Orbi AC product line is long in the tooth and one might imagine that significant resources are dedicated to resolving major issues with the AX product line (which inhibit further sales) or to the new WiFi7 products in the pipeline.
Having only Netgear WiFi equipment, I have no idea how often other vendors update firmware or how their update process works in practice.
- KevinLiTNETGEAR Moderator
Hello JoeM845 ,
Kevin
Community Team
- RocketSquirrelLuminary
The very sparse release notes state
- Various Armor bug fixes
- Various SPC bug fixes
I have no idea what Armor and SPC are. What are they?
Armor is router based security app.
SPC is Smart Parental Controls.
- JoeM845Luminary
Thanks. "Optional update" makes sense. I do not know how I -- a basic user -- am supposed to figure this out. Should I expect Netgear's documentation to provide any guidance?
The Release Notes do not say optional. Nor do they provide any recommendations. They list the two features (Armor & SPC), but they do not say the bug fixes are only applicable to setups using those features.
The option to check for updates says no newer firmware and not o newer mandatory firmware
Thanks again,
Joe
Why I posts additional information on new updates when they come out.
Up to users if they wanna update or not.
Good luck.
