JohnWillard
Feb 03, 2024Aspirant
pfSense VLAN with GS110EMX
Hello there. I am trying to get some pfSense VLANs set up. Two physical ports on my pfSense box are connected to GS110EMX Smart Switches. Is there any way to make a VLAN tag for the switch itself to ...
- Feb 04, 2024
I was able to actually figure it out, but thank you all! Closing this thread!
BrianL
Feb 04, 2024NETGEAR Moderator
Hi JohnWillard,
Once you have defined, and configured the VLANs (trunk, access ports, and PVID) from your router, you may want to consider configuring LAG between your router and the NETGEAR switch since you are planning to put two ports to link them. You may check the steps on how to configure LAG from this manual on pages 51-55.
Kind regards,
- JohnWillardFeb 04, 2024Aspirant
