t84a
Jan 31, 2017Aspirant
Port based VLANs on GS108E
Greetings folks. I need some help here. I’m new to Netgear ProSafe as well as VLANs. The port based VLANs attracted me to the GS108E and I’m hoping I bought the right device. Currently, I have ...
- Feb 22, 2017
Sorry for the delay. I ended up going with another Untangle. Thanks for the replies.
DaneA
Feb 01, 2017NETGEAR Employee Retired
Hi t84a,
Welcome to the community! :)
The GS108E switch is not capable of being a DHCP server. In order to achieve your goal, you will need to replace the ASUS RT-N66U with a VLAN-aware router that will also handle the DHCP for each VLAN. Since you have a dual-WAN setup, I suggest you the FVS336Gv3 VPN firewall router. Kindly check its specifications on the data sheet here.
DaneA
NETGEAR Community Team
t84a
Feb 01, 2017Aspirant
Thanks. Can I replace the ASUS router and the Netgear GS108E with FVS336Gx3 and call it a day?
- DaneAFeb 01, 2017NETGEAR Employee Retired
t84a,
You may replace the ASUS RT-N66U router together with the GS108E switch with an FVS336Gv3. However, you might want to consider this scenario: what if in the near future you need to add VLAN-aware devices like NAS or VoIP phones that needs port VLAN tagging. The FVS336Gv3 doesn't support VLAN tagging. You will need a switch that supports 802.1Q VLANs.
DaneA
