WesL01
Oct 28, 2021Aspirant
Port forwarding two things through the same port
I am trying to port forward two things through the same port, I add one and it works fine. but when I try and add the second to the same port it says that that one is already in use.... The port is 4...
WesL01
- schumakuOct 28, 2021Guru - Experienced User
Assume you talk of some ISP or third party NAT routers (probably on some Netgear NAT router supporting ReadyShare according to the screenshot), not on the subject switches.
Simple: You can port forwarding one port always to a single device or LAN IP.
Consult with this "Miners" application support or community for having multiple servers active at the same time.
- WesL01Oct 28, 2021Aspirant
Both Servers are ran through a Netgear GS308E "Smart Switch", so I was told to post my question here. When I plug in my LAN ip it says that cant cant be a LAN IP.
These switches are just L2 devices ... no L3 or IP handling, just simple L2 forwarding.
Whatever you tried to configure before this message showed up - you can't configue port forward to the router LAN IP.
