Woolfie001
Aug 22, 2017Follower
Port trunking on GSS108E
Hi everyone,
Just a quick question, as to me it's not entirely clear from Netgear's website or documentation:
Does the Click Switch GSS108E support VLAN port trunking or not ?
Following pages seem to indicate that it does (I do not see any explicit restriction on GSS108E concerning port trunking):
http://netgear.com/business/products/switches/click/click-switch.aspx#tab-highlights
http://netgear.com/business/products/switches/click/click-switch.aspx#tab-features
While following page says port trunking is limited to GSS116E only !
http://www.netgear.be/home/products/networking/switches/GSS108E.aspx
Also different review sites have different views on the subject, as some state that they succesfully created a trunk with this switch (http://www.storagereview.com/netgear_prosafe_click_switch_series_review) while others seem to indicate that trunking is impossible unless you have a GSS108EPP or GSS116E, both of which in my case are overkill (no need for PoE or 16 ports).
Does anyone have any experience with this switch ?
Thanks
Hi Woolfie001,
Welcome to the community!
GSS108E supports 802.1q VLAN port trunking as the model falls under Web Managed Click Switch.
Please refer to this manual(page 33).
- JohnC_VNETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if you still need further assistance and just in case that the reply would be the answer to your issue. I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
