patrickmx
Nov 01, 2023Aspirant
Ports unavailable on GS724Tv3
Hello I bought a second-hand GS724Tv3. It seems to run correctly except that it has disabled 8 port (g1 to g8) : on connecting any device, not even the "link" LED lights up. I intent to check all p...
JBCIG
Nov 20, 2023Aspirant
Log into the switch.
Click on the Switching tab.
Click on Ports.
Click on Port Configuration.
Ensure all ports (g1-g28) have Admin Mode enabled (that's really what turns it off/on; nothing about "admin").
I typically disable ports to prevent rogue devices from connecting without my permission. If that doesn't help, try resetting it to factory default, then redo the setup you need. Factory default is at Maintenance tab, Factory Default link. Good luck.
patrickmx
Thank you very much.
Saddly, it doesn't change anything.
Regards.
