saed123's avatar
saed123
Pro Safe GS724TPS Compatibility with Aruba Instant On AP 22
Greetings Netizens, Is the Pro Safe GS724TPS POE compatible with Aruba Instant On AP 22 ? I want to leverage the Pro Safe's POE feature.
  • DaneA's avatar
    Aug 12, 2021
    saed123,
    Welcome to the community! :)
    The GS724TPS supports Active PoE on all 24 ports.  It supports the following PoE functions:
    1)  Smart Power Managed function handles the power of each port in the event of limited available power.
    2)  Supports the 24-Port PoE function as follows:
    - 15.4W for 12 ports
    - 8W for 24 ports
    for a total of 192W for PoE. The GS724TPS, using data pairs (RJ-45 1, 2, 3 and 6 pin), provides power to the PD.
    If the Aruba Instant On AP 22 supports Active PoE then it will work with the GS724TPS.
    Let me share the article below:
    Active or Passive PoE, That is the Question
    DaneA
    NETGEAR Community Team
ProSupport for Business
