Tallightskinned's avatar
Oct 21, 2023
Cax80 compatibility
What mesh devices are compatible with the cax80? I'm kinda new to networking. I really don't want to switch modems but will if I absolutely have to. Need help with building a mesh network with the cax80 if possible.
  • microchip8's avatar
    microchip8
    Oct 21, 2023
    The router part of your CAX80 is not compatible with Mesh so you'll have to buy a complete Mesh package (router + satellites) so that's why I mentioned putting the CAX80 in bridge otherwise you'll end up with 2 separate LANs that can't talk to each others (double NAT)
    You can control it by going to http://192.168.1.1
  • You need to put the CAX80 in bridge mode, then you can use any Mesh package (Orbi, RBR, etc) or from another vendor.
    • Tallightskinned's avatar
      Tallightskinned
      Thanks for the reply! How do I do that? After I do that do I just purchase the satellites like mk63?
        microchip8
        Master
