saed123
Aug 12, 2021Aspirant
Pro Safe GS724TPS Compatibility with Aruba Instant On AP 22
Greetings Netizens, Is the Pro Safe GS724TPS POE compatible with Aruba Instant On AP 22 ? I want to leverage the Pro Safe's POE feature.
- Aug 12, 2021
Welcome to the community! :)
The GS724TPS supports Active PoE on all 24 ports. It supports the following PoE functions:
1) Smart Power Managed function handles the power of each port in the event of limited available power.
2) Supports the 24-Port PoE function as follows:
- 15.4W for 12 ports
- 8W for 24 portsfor a total of 192W for PoE. The GS724TPS, using data pairs (RJ-45 1, 2, 3 and 6 pin), provides power to the PD.
If the Aruba Instant On AP 22 supports Active PoE then it will work with the GS724TPS.
Let me share the article below:
Active or Passive PoE, That is the Question
DaneA
NETGEAR Community Team
DaneA
Aug 12, 2021NETGEAR Employee Retired
- 8W for 24 ports
DaneA
saed123
Aug 13, 2021Aspirant
Thank you so much. According to Aruba, it is an 802.3af class 3 device. Does this mean it will work with the GS724TPS.
Electrical specifications
SpecificationDescription
Power |
- schumakuAug 13, 2021Guru - Experienced User
802.3af PSE does support any 802.3af PD - class 1...3, and class 0).
