DominikHoffmann
Sep 30, 2022Aspirant
Problems with PoE power budget on GS108PEv3 switch?
I have a GS108PEv3 PoE managed switch, which I am using to power three EnGenius EWS357APv3 APs. My WiFi is acting up every so often. My clients try to connect, temporarily do so (< 1 s), but then fai...
Oct 01, 2022Guru - Experienced User
Poor keystone jacks or pushdowns can cause lots of issues.
Does it stay stable if you're just using the 2x AP's?
Or does it stay stable if you power the one (or try more than 1) off a power supply and not the POE (for testing)
DominikHoffmann
Oct 01, 2022Aspirant
I had the issue go away once, so far, when I powered down one of the APs. I have yet to check, whether the PoE MAX light comes on, when it happens again.
