silverbuzz
Jan 22, 2017Aspirant
Prosafe 8 port gigabit switch GS108E
Hello, I have a question about using this switch. I am under the impression I can split the internet signal with it and send it to a blueray player (with netflix) and my DVR. Is this possible ?
- Jan 23, 2017
You're welcome! :) I am glad to know that the network diagram has helped and both units now work. :D
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
silverbuzz
Jan 23, 2017Aspirant
Thank you for your help ! I have the switch hooked up as you described and both units work !!
- DaneAJan 23, 2017NETGEAR Employee Retired
Cheers,DaneA
