Runaway1954's avatar
Dec 15, 2021
PoE+ Gigabit Ethernet Plus Switch
I have not yet purchased this device, but I am contemplating doing so.
I have downloaded the manual, and I've searched through it to answer one very important question.
If, through ignorance, carelessness, or stupidity, a person were to plug an ethernet cable from a computer, into a PoE  powered connection, would there be any damage?  I quote from page 81 of the manual:
6. On the SETTING menu, open the menu for the port number.
The port settings display.
7. Click the EDIT button.
8. From the Port Power menu, select one of the following options:
• Enable: The port’s capacity to deliver power is enabled. This is the default setting.
• Disable: The port’s capacity to deliver power is disabled.
This leads me to believe that I can turn power OFF on 1 or more ports, and use that port as a standard ethernet, with no damage to any devices involved.  But, what if I then plug another device into another port, without disabling the power on that port?
I believe that I read somewhere that a PoE switch queries newly connected devices, to establish power requirements.  However, I'm not certain how that works.  If someone plugs in a laptop that needs no power, will the device just be assigned an IP address, and work just like any unpowered ethernet connection?  Or, might something melt down somewhere?
Needless to say, if I permitted someone to slag a device costing $1000 up to maybe $5000, I would be very unpopular for a long time to come!  I could build a secure, locked enclosure to put the switch into, but that may prove awkward, and unsightly, again making me unpopular.
Thanks for any help!
  • Runaway1954,
    There is no harm connecting a PC/laptop to any PoE port of the PoE switch.  You don't have to worry about it.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Runaway1954,
    DaneA
    • Thank you DaneA
      PoE ports are backward compatible, and safe for connecting to devices that need no power.  That takes a load off my mind, trying to figure out what I'm doing.
      • DaneA's avatar
        DaneA
        Runaway1954,
        You're welcome! :)   If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
        The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
        DaneA
  • schumaku's avatar
    schumaku
    All industry compliant IEEE like 802.3af, 802.3at, 802.3bt (type 3) and 802.3bt (type 4) are perfectly secure. Unless a connected device (the PD, powered device) does negotiate power delivery with the PSE (Power source equipment), there is no power applied.
    The technology for this can vary widely, from some resistors over the data pairs, pulse signals, over to LLDP-MED (link layer discovery protocol). Backwards compatibility is always granted.
    It can be very different with all these "passive" and whatever proprietary or legacy solutions providing power over an Ethernet data link.
    PS. Uncertain what "this device" you have in mind - the tagged GS308E isn't a PoE switch.
    • Runaway1954's avatar
      Runaway1954
      Tutor
      schumaku
      Hmmm - I'm on the Netgear Amazon store, at this address -
      https://www.amazon.com/NETGEAR-8-Port-Gigabit-Ethernet-Unmanaged/dp/B08MBFLMDC?ref_=ast_sto_dp&th=1
      I click the button labeled "8 Port | 8xPoE+ 62W $99.90"  Other options are available, both managed, and unmanaged, from a 5 port unmanaged with 4xPoE63W, up to a 48 port managed 24 of those ports PoE+ 380W.  There is an 8 port unmanaged 4xPoE53W which could probably suit my needs, but for ten bucks more (I think that was the price difference), I'm opting for the managed switch.
      The goal here, is to introduce some security cameras to the network, and I believe PoE to be my best option.  I intend to set up two cameras immediately, then to take stock of the situation, and add two more cameras once I've figured out exactly what I've got.
      I sure hope that I'm looking at what I think I'm looking at.
      Ahhh, I think I see the source of confusion - the model number I'm looking at is GS308EP   This is the exact address of the manual I am looking at - https://www.downloads.netgear.com/files/GDC/GS305EP/GS305EP-EPP_GS308EP-EPP_UM_EN.pdf  The dropdown list for the tag doesn't include the EP, EPP found in the manual, or on Amazon.
ProSupport for Business
