Runaway1954
Dec 15, 2021Tutor
PoE+ Gigabit Ethernet Plus Switch
I have not yet purchased this device, but I am contemplating doing so. I have downloaded the manual, and I've searched through it to answer one very important question. If, through ignorance,...
- Dec 16, 2021
There is no harm connecting a PC/laptop to any PoE port of the PoE switch. You don't have to worry about it.
DaneA
NETGEAR Community Team
schumaku
Dec 16, 2021Guru - Experienced User
All industry compliant IEEE like 802.3af, 802.3at, 802.3bt (type 3) and 802.3bt (type 4) are perfectly secure. Unless a connected device (the PD, powered device) does negotiate power delivery with the PSE (Power source equipment), there is no power applied.
The technology for this can vary widely, from some resistors over the data pairs, pulse signals, over to LLDP-MED (link layer discovery protocol). Backwards compatibility is always granted.
It can be very different with all these "passive" and whatever proprietary or legacy solutions providing power over an Ethernet data link.
PS. Uncertain what "this device" you have in mind - the tagged GS308E isn't a PoE switch.
Runaway1954
Dec 16, 2021Tutor
Hmmm - I'm on the Netgear Amazon store, at this address -
https://www.amazon.com/NETGEAR-8-Port-Gigabit-Ethernet-Unmanaged/dp/B08MBFLMDC?ref_=ast_sto_dp&th=1
I click the button labeled "8 Port | 8xPoE+ 62W $99.90" Other options are available, both managed, and unmanaged, from a 5 port unmanaged with 4xPoE63W, up to a 48 port managed 24 of those ports PoE+ 380W. There is an 8 port unmanaged 4xPoE53W which could probably suit my needs, but for ten bucks more (I think that was the price difference), I'm opting for the managed switch.
The goal here, is to introduce some security cameras to the network, and I believe PoE to be my best option. I intend to set up two cameras immediately, then to take stock of the situation, and add two more cameras once I've figured out exactly what I've got.
I sure hope that I'm looking at what I think I'm looking at.
Ahhh, I think I see the source of confusion - the model number I'm looking at is GS308EP This is the exact address of the manual I am looking at - https://www.downloads.netgear.com/files/GDC/GS305EP/GS305EP-EPP_GS308EP-EPP_UM_EN.pdf The dropdown list for the tag doesn't include the EP, EPP found in the manual, or on Amazon.
