firoz3321
Nov 16, 2021Guide
R6220 Router gigabit ethernet supported ?
I have been using the Netgear R6220 router.
Recently i upgraded my internet speed from 75mbps to 125mbps.
But the max speed never crosses 80~90 mbps.
The service provider said the router does not have the gigabit ethernet port so the speeds are limited by the router.
Can someone confirm if this is true ?
- I'd take it up with your ISP. Tell them its a gigabit router but only connecting to 10/100mbps. - Its not something that you can change as its auto-negotiates. - If you can't change out the cable, then they can test it. - If you could directly connect your pc to have it work, then you could test it.
- plemansGuru - Experienced Userthe router is gigabit. What modem is it connected to? What speeds do you get from the modem? Have you tried replacing the cables from modem--router and router----device? Make sure you test hardwired. - Hi thank you for the confirmation regarding gigabit support. - There is no modem connection, an ethernet cable is provided by the ISP directly. - PPPoE connection. The ISP says others are able to get 125mbps speeds so it must be the router issue. - plemansGuru - Experienced Userwhat speeds do you get directly connected to the fibre connection? Have you tried a simple factory reset on the router? Are you testing wired?
