Mastra11
Apr 12, 2021Apprentice
Gigabit ethernet switch differences
Hello, I'm looking at several plug and play gigabit ethernet switches, explain to me what differences there are between: GS208-100PES, GS608-400PES, GS308 what are the differences between these three switches? what is the best? thank you.
I see. If that's the case, then that will be depending on your taste :) to which one is the most suitable design that will fit in your house.
John
NETGEAR Community Team
- Mastra11Apprentice
Hello anyone can tell me what differences there are? what is the best? thank you
- JohnC_VNETGEAR Employee Retired
In terms of their performance, these switches are the same but the difference is the physical design which the GS208 and GS608 are made out of plastic and GS308 is metal. I suggest you get the GS308 as it is more suitable for a business environment.
John
- Mastra11ApprenticeOk thanks, I have to put it at home so for home use.
