Mastra11
Apr 12, 2021Apprentice
Gigabit ethernet switch differences
Hello, I'm looking at several plug and play gigabit ethernet switches, explain to me what differences there are between: GS208-100PES, GS608-400PES, GS308 what are the differences between these three...
JohnC_V
Apr 16, 2021NETGEAR Employee Retired
In terms of their performance, these switches are the same but the difference is the physical design which the GS208 and GS608 are made out of plastic and GS308 is metal. I suggest you get the GS308 as it is more suitable for a business environment.
John
NETGEAR Community Team
Mastra11
Apr 16, 2021Apprentice
Ok thanks, I have to put it at home so for home use.
