Mastra11
Apr 12, 2021Apprentice
Gigabit ethernet switch differences
Hello, I'm looking at several plug and play gigabit ethernet switches, explain to me what differences there are between: GS208-100PES, GS608-400PES, GS308 what are the differences between these three...
Mastra11
Apr 14, 2021Apprentice
Hello anyone can tell me what differences there are? what is the best? thank you
- JohnC_VApr 16, 2021NETGEAR Employee Retired
In terms of their performance, these switches are the same but the difference is the physical design which the GS208 and GS608 are made out of plastic and GS308 is metal. I suggest you get the GS308 as it is more suitable for a business environment.
John
NETGEAR Community Team
- Mastra11Apr 16, 2021ApprenticeOk thanks, I have to put it at home so for home use.
