vincentw
Sep 16, 2017Initiate
prosafe gs110tp. can I plug a device that does not need power into any socket?
Hi there, Would like to know if I can plug a non poe device into any RJ45 socket on a Pro safe GS110TP, or could this cause damage because of the power being sent to it. Hope this question makes se...
- Sep 24, 2017
I just want to follow-up on this. Let us know if you have further questions.
Otherwise, if ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
NETGEAR Community Team
DaneA
Sep 24, 2017NETGEAR Employee Retired
Cheers,
DaneA
vincentw
Sep 24, 2017Initiate
Hi DaneA,
Thank you so much, that answers my question in full.
Thanks again
Vince.
