fdeutsch
May 03, 2022Aspirant
ProSafe GS748T doesn't refresh Gateway
Hi all, I am configuring a GS748T to use our new fiber router. I changed the default gateway in the IP config options to the new one, the switch uses the new gateway to ping and tracert but conn...
May 03, 2022Guru - Experienced User
Do you mean the old devices are still using the IP address of the old gateway?
Not sure exactly what you're saying here.
- fdeutschMay 03, 2022Aspirant
Yes, computers on my network are still exiting the network using the old gateway (xx.1.1) instead of the new fiber one (xx.1.254) even though I changed the gateway address on the switch IP config
