fdeutsch
May 03, 2022Aspirant
ProSafe GS748T doesn't refresh Gateway
Hi all, I am configuring a GS748T to use our new fiber router. I changed the default gateway in the IP config options to the new one, the switch uses the new gateway to ping and tracert but conn...
fdeutsch
Yes, computers on my network are still exiting the network using the old gateway (xx.1.1) instead of the new fiber one (xx.1.254) even though I changed the gateway address on the switch IP config
May 03, 2022Guru - Experienced User
did you reboot the devices connected and not just the switch/router?
