jbouwh
Sep 13, 2012Tutor
Prosafe Plus Configuration Utility - HTTP request error
I own two Netgear Smart swiches: Regards, Jan
- Oct 09, 2012I Fixed it!!! :): The problem seemed to be caused by the 'Internet Connection Sharing Service (ICS)'.
Some how I have been configuring this service on my laptop. When I stop this service, the utility works again. Because I do not need this service most of the time I changed the startup mode of this service to manual.
jbouwh
Sep 14, 2012Tutor
Already saw that thread, seems a simular problem.
I think the error is in NsdpManager.exe:
I think this is not an Adobe Air application. Only the GUI requires Adobe AIR.
SOAP 1.1 fault: SOAP-ENV:Server [no subcode]
"Either the application has not called WSAStartup, or WSAStartup failed.
Detail: accept failed in soap_accept()
