jbouwh
Sep 13, 2012Tutor
Prosafe Plus Configuration Utility - HTTP request error
I own two Netgear Smart swiches: Regards, Jan
- Oct 09, 2012I Fixed it!!! :): The problem seemed to be caused by the 'Internet Connection Sharing Service (ICS)'.
Some how I have been configuring this service on my laptop. When I stop this service, the utility works again. Because I do not need this service most of the time I changed the startup mode of this service to manual.
jbouwh
Feb 20, 2013Tutor
I have been struggeling with VM ware as well, but that was not the problem.
I have VMware player installed.
I am using a 64bit version of Windows 7. And yes, using a Win XP station is an exelent work-a-round.
Good-luck.
Good-luck.
