tdgsupport
May 18, 2022Aspirant
ProSAFE S3300-52X-PoE+ SFP issues
I am having a problem using the SFP port on my ProSafe S3300 to a different switch (Planet). I could not source a Netgear SFP module from anywhere in a timely manor but as I understand it SFP isn't c...
tdgsupport
In case it is useful here is a screenshot of my ports and their status. If any other screens are helpful just let me know.
- DaneAMay 23, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
If you are not using the compatible SFP module for the S3300-52X-PoE+, then there is no guarantee that it will work. NETGEAR recommends to use the compatible SFP modules for the S3300-52X-PoE+ as indicted on page 14 of its data sheet here.
DaneA
NETGEAR Community Team
