beachmat's avatar
Oct 09, 2018
PVID port priority
On the GS724v4 PVID screen, what is the port priority setting for, and does it tie in with other QOS or COS settings? I can't find anything about it in the manual.
  • schumaku's avatar
    Oct 09, 2018
    In the Port Priority field, you can specify the default 802.1p CoS PCP priority assigned to untagged packets arriving at the port. Possible values are 0–7. Default 0 (BE, Best Effort).
    There is a tiny (?) on many Netgear switch Web UI, opening some context sensitive information - always worth a try.
ProSupport for Business
