beachmat
Oct 09, 2018Guide
PVID port priority
On the GS724v4 PVID screen, what is the port priority setting for, and does it tie in with other QOS or COS settings? I can't find anything about it in the manual.
- Oct 09, 2018
In the Port Priority field, you can specify the default 802.1p CoS PCP priority assigned to untagged packets arriving at the port. Possible values are 0–7. Default 0 (BE, Best Effort).
There is a tiny (?) on many Netgear switch Web UI, opening some context sensitive information - always worth a try.
schumaku
Oct 09, 2018Guru - Experienced User
MultiByte
Nov 03, 2018Tutor
I was confused on CoS Port Priority field. On Cisco documentation, page 27-3, printed 0 being the lowest priority and 7 the highest. Netgear also stated same as above. Is there a different meaning to lowest/highest priority vs Best Effort?
