scain
Oct 06, 2018Aspirant
Radius web authentication GS108T
I've configured this switch to use the radius server on my network for authentication in the web UI. However, after logging in successfully, it appears that the admin user doesn't possess the same l...
- Oct 11, 2018
Hi scain
Welcome to the community! :)
I inquired your concern to the higher tier of NETGEAR Support. As per the higher tier of NETGEAR Support, in order to give admin access, in the RADIUS setting, a policy needs to be created. Then, in the policy, a service type with attribute "Administrative" needs to be created. Kindly check the image below:
DaneA
NETGEAR Community Team
