robfantini's avatar
robfantini
dhcp snooping troubleshooting
Hello    I  am in the process of trying to migrate from a gsm7353s [ m4100] to this new 10G switch.     dhcp snooping has been turned on.   however clients are not getting dhcp.    ...
  • robfantini's avatar
    robfantini
    Jun 09, 2018
    it looks like this switch is not a replacement for our GSM7352Sv2 48 .
    our current switch has a lot more capability like UDP Relay  and being able to set up at UDP Relay Global Configuration - our dhcp servers to use for udp relay.
    thanks anyway for the help!
ProSupport for Business
