KevinB15
Mar 29, 2017Aspirant
Fiber Connection
Have a GS752TXS w/ 4 10G fiber connections and a GS728TX-100NES w/ 2 10G fiber connections, both using AXM761 modules. On the GS752, port 49 is connected to a NAS, port 50 is connected to a server...
- Apr 04, 2017
Hi KevinB15,
It very helpfull about the provided information.
On GS752TXS Port 51,52 are stack ports. So they can't be used for ethernet connection.
We need to change port 51,52 from stack mode to ethernet mode with following steps.
1.Go to "System /Stacking/Stack Port Configuration"
2.Select port 51/52.
3.Change configured stack mode to Ethernet.
4.Click Apply on the right bottom。
5.Restart the switch.
Hope it helps
Best Regards
Carl
Carl_z
Apr 04, 2017NETGEAR Expert
Hi KevinB15,
Hope it helps
Best Regards
Carl
KevinB15
Apr 05, 2017Aspirant
Ok, I had already changed it, I didn't do the restart.
Thanks for the help.
