CraftyAndy
Dec 19, 2016Aspirant
GS110TP IGMP querying
 Hi there,    I was having some multicast issues and I thought perhaps it was due to not having an IGMP Querier on the network so I purchased the GS110TP to replace the switch I was using.     I belie...
- Dec 20, 2016
Hi CraftyAndy
Welcome to Netgear Community!
Beside your current configuration, there something to be added.
1.switching >muticast>igmp snooping>IGMP snooping vlan configuration. Here add vlan 1 as igmp snooping vlan.
2.switching >muticast>igmp snooping querier>Querier configuration. Here enable Querier Admin Mode,add you can set IGMP Version,Query Interval as you want.
After add this you can check at switching >muticast>igmp snooping querier>Querier vlan status, it should show vlan 1 Operational State is Querier. Also ,at this time you can capture igmp query message via Wireshark.
Regards
Carl
Netgear Employee
Carl_z
Dec 20, 2016NETGEAR Expert
Hi CraftyAndy
Regards
Carl
Netgear Employee
CraftyAndy
Dec 20, 2016Aspirant
Hi Carl,
I had already done step 2 above (I realize now that my screenshot did not capture that..), but I had not done step 1. I had tried to but rather than clicking "add" I hit "apply" and nothing happened. When I re-did step 1 and hit "add" the entry was added and I now see the queries and the snooping table is being populated. Thank you!!
