TadH
Nov 15, 2024Aspirant
GS305E Static IP
I'm trying to assign a static IP to my GS305E. Seems it won't allow me to use a 10.1.1.x address, but it will allow a 192.168.x.x address. Why should this matter? It will accept a 10.1.1.x address vi...
schumaku
Nov 16, 2024Guru - Experienced User
Have deployed a different IP subnet here in my new home, since the ISP router defaulted to the ubiquitous 192.168.1.x/24, so took the plunge and disbled the DHCP mode on the GS308E (very similar to your GS305E):
Can't follow you what you want to say with "it does not take" ....
Needless to say, but I'll do it anyway: The default gateway must of course reside in the same IP subnet and IP address range.
Is there a recent or better current firmware to your GS305E switch? Just in case ...
