IOTdiot
Mar 28, 2019Tutor
GS752TP v1 to v2 - Same backup file?
My GS752TP-100NAS (v1?) just stopped working and it seems Netgear is sending me a GS752TP-200NAS (v2?) as a replacement.
On the support page you can select v1/v2 and they have different firmwar...
- Mar 29, 2019
FYI for anyone wondering; I just manually reconfigured my new v2 switch. I did not use the v1 config or try to import it as the new webGUI looks different than the old one.
IOTdiot
Mar 28, 2019Tutor
I just read this in the GS752TPv2 release notes, does this mean I cannot use a v1 backup config file?
Limitations:
- Configuration migration from older devices GS728TP/ GS728TPP/ GS752TP to new devices GS28TPv2/ GS728TPPv2/ GS752TPv2 is NOT supported.
