thapchild's avatar
thapchild
Help understanding, and proper deployment of STP (loop protection).
I just installed 3 GS752TPS switches in a stacked environment.  These switches supply a 20,000 square foot office building for various tennants.  These Tennants all run on seperate Vlans, but can ran...
  • Carl_z's avatar
    Apr 20, 2017
    Hi thapchild,
    Welcome to the community!
    By default GS752TPS have enable RSTP. And I think the default settings can meet your requirements. Once there is a looped switch  connected to the GS752TPS , the port on the GS7582TPS that connected to the looped switch would be disabled by RSTP.  So the looped switch would not affect the entire building.
    To make sure stp have been enabled,you can check it by following steps,
    Step1. Go to "Switching/STP "   Spanning Tree State should be enable ,STP Operation Mode RSTP(STP is also ok,by default it is RSTP)
    Step2. Go to "Switching/STP/Advanced/CST Port Configuration"   Port STP status should be "Enable"
    For more details about STP feature of GS75TPS, you can refer here,  page 122 to 134.
    Best Regards
    Carl
    Netgear Employee
ProSupport for Business
