gparkerCOB
Jun 21, 2018Aspirant
how to enable Jumbo Frames on XS748T? Can't find the setting.
I have searched and found a article on the site showing how to enable Jumbo Frames on Pro Safe switches, but the interface in the XS748T looks different than their example and I can't find where to e...
- Jun 27, 2018
Hi gparkerCOB
Sorry for late to back, I missed your reply.
For XS748T Jumbo Frames is enabled by default. You can just use Jumbo Frames without any configurations.
BestRegards
Carl
Carl_z
Jun 21, 2018NETGEAR Expert
Hi gparkerCOB,
Welcome to the community!
You can go to "Switching/Ports/Port Configuration/" There is a value named "Maximum
Frame Size". Just set this value to max to enable Jumbo Frames.
Best Regards
Carl
Netgear Employee
gparkerCOB
Jun 27, 2018Aspirant
Carl,
Any ideas why our switch doesn't have that setting you talked about?
Thanks
- Carl_zJun 27, 2018NETGEAR Expert
Hi gparkerCOB
BestRegards
Carl
