ramram
Feb 08, 2017Aspirant
Need to secure a GS110TP switch
Hi all We just got a GS110TP managed switch. We need it to recognize only a set of network devices and drop the rest. Trying to set MAC filtering but for some reason its not working and all devic...
DaneA
Feb 26, 2017NETGEAR Employee Retired
I just want to follow-up on this. Were you able to access the article I've shared and used it as your reference guide? Also, were you able to try to configure Port Security on your GS110TP switch?
DaneA
NETGEAR Community Team
ramram
Feb 26, 2017Aspirant
yes i managed. the problem is that i was allocating all ports where in reality you should always like a vacant port for the uplink
thanks for your help
- DaneAFeb 26, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad the problem is now resolved. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Cheers,DaneA
