Jonathanoee
Apr 28, 2022Aspirant
Very very Noisy Switch - XS724EM
Recently bought a new Switch to our office to be able to run 10Gbit. This one: XS724EM - 24-Port 10-Gigabit/Multi-Gigabit Ethernet Smart Managed Plus Switch And I think the fans are going insane...
- May 03, 2022
It does sound like we've got similar environments in terms of temperature, 10G clients etc. but opposite manifestations of a fan issue. It could be faulty hardware or it could be a quirk of the way this firmware version interprets the sensor data.
Either way, the periodic fan ramp-up does not appear to be intended behavior.
In my case, there's some doubt as to whether some fans will selectively spin down under standard ambient temperature in an attempt to prioritize noise reduction over cooling. This is what I've been told directly by Netgear technicians, even though it seems bonkers. But that approach would make your XS724EM's jet engines the very thing they're trying to avoid.
I'd call Netgear support, as your device should be fully warrantied, and ask them to replace it or issue firmware to correct the issue.
Another potential solution is for Netgear to give the admin more visibility and control over fan speeds and temperature. If you wouldn't mind, please upvote my recommendation to that effect.
nsne
Apr 28, 2022Virtuoso
Sounds like you've got the opposite problem to me, which is that 2/3 fans on my XS724EM aren't spinning at all after boot. Yet there's no indication of a fan error. It's blissfully quiet, but I'm worried about its cooling performance.
Unfortunately, I'm stumped as to causes. Maybe there's a bug in this firmware to do with cooling and how the sensors inform the fan profiles. Or just faulty sensors.
A couple of questions that might help a little with troubleshooting.
- What firmware version are you running?
- Is the Fan LED on the front panel illuminated?
- What's the general ambient temperature of your operating environment?
- Could the fans be spinning up in response to heavy 10G data traffic?
I'm not aware of a fanless 10G switch and I'm not sure I'd trust one if I were. A known byproduct of 10G copper is significantly more heat than 1G/2.5G connections.
- JonathanoeeMay 03, 2022Aspirant
Thanks for your questions!
The latest I believe, Firmware Version 1.0.2.0
No, its not. Not even when it runs in "High Noise" mode.
A normal Office, around 22 Celsius - its mounted in a rack, with lots of empty space over and below.
Yes, probably. But only running only 4 ports with 10G for now (since all clients doesn't have 10G cards installed yet)
And running our Server with double 10G bit Linked Aggregation. (Synology server)
- nsneMay 03, 2022Virtuoso
Thanks alot for your thoughts and help with this. I will check with Netgear!
