thatnoobguy's avatar
thatnoobguy
VLAN Setup
Hello Netgear community,  I just recently purchased a GS108Tv2 switch, and I'm trying to configure two VLANs on the switch. After configuring my PfSense box and my GS108Tv2 switch, I connected a PC ...
  • DaneA's avatar
    Oct 15, 2015
    Hi thatnoobguy,
    It seems that your VLAN configuration on the GS108Tv2 switch is correct.  Let us isolate the problem.  Here are the steps:
    1. Disconnect the GS108Tv2 switch from the PfSense router.
    2. Connect a PC directly to a port on the PfSense router that is a member of VLAN20.
    3. Check if the PC gets a valid IP address from VLAN20 configured on the PfSense router.  Check also if you can ping 192.168.20.1/24 and able to access the internet.
    4. Connect a PC directly to a port on the PfSense router that is a member of VLAN30.
    5. Check if the PC gets a valid IP address from VLAN30 configured on the PfSense router.  Check also if you can ping 192.168.30.1/24 and able to access the internet.
    Kindly answer the questions below:
    a. From step 3, are you able to get a valid IP address from VLAN20?  Are you able to ping 192.168.20.1/24 and able to access the internet?
    b. From step 5, are you able to get a valid IP address from VLAN30? Are you able to ping 192.168.30.1/24 and able to access the internet?
    c. What is the current firmware version of the GS108Tv2?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
ProSupport for Business
