ptoschi's avatar
ptoschi
Redundant SFP+ connection between switches (GS752TXS and M4300-8x8f)
Hello, I have two GS752TXS switches in my server rack. I use the SFP+ ports to connect them with each other and with my servers. I now want to split my servers in two locations with each location ha...
  • omicron_persei8's avatar
    Jul 26, 2016
    @Modos: What the hell happened to my reply??? Are you serious???
    @OPOP
    You could stack both GS752TXS together, stack both M4300 together and have a two cables LAG between the two stacks -> you get the redundandy, reduce the amount of configuration, don't need STP, increase the efficiency of load balancing on the switches
    To build the stacks, you could use Direct Attached Cables such as AXC761 or AXC763, which are 10Gbps copper, therefore MUCH less expensive than fiber modules -> you get same performance for lower price
    Diagram: https://i.imgur.com/3iYsfYF.png
ProSupport for Business
