Neeraj79
Nov 26, 2018Initiate
Remote syslog server
Hi, we have a neatgear GS724T running firmware 6.3.1.4. I am using it as a pure L2 switch with no routing enabled.
I am managing it via its default IP 192.168.0.239 . My requirement is to send sys...
- Nov 27, 2018
Thank you Schumaku & DaneA. I was managing it by plugging a computer to that very same default VLAN and configure an address in the 192.168.0.x/24 subnet instead of the "normally" used IP subnet. Upon adopting the switch's ipv4 configuration to the network , configuring default gateway etc it is now working.
