Neeraj79
Nov 26, 2018Initiate
Remote syslog server
Hi, we have a neatgear GS724T running firmware 6.3.1.4. I am using it as a pure L2 switch with no routing enabled.
I am managing it via its default IP 192.168.0.239 . My requirement is to send sys...
- Nov 27, 2018
Thank you Schumaku & DaneA. I was managing it by plugging a computer to that very same default VLAN and configure an address in the 192.168.0.x/24 subnet instead of the "normally" used IP subnet. Upon adopting the switch's ipv4 configuration to the network , configuring default gateway etc it is now working.
Neeraj79
Nov 27, 2018Initiate
DaneA
Dec 02, 2018NETGEAR Employee Retired
Hi Neeraj79,
Thank you for the update. I'm glad to know that you were able to figure it out and its it is now working.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
