cwagz
Aug 20, 2022Star
Replaced GS724Tv4 with GS728TXP and AirPrint Will No Longer Work
Hi, I had a working configuration with IGMP snooping enabled per directions found in the forum. All mdns functions on the network were working. Yesterday I replaced my GS724Tv4 with a GS728TXP ru...
- Dec 03, 2022
Quick update. I was provided with a pre-release firmware for testing. The firmware fixes the issue I was encountering. I assume it will be released publicly soon.
DaneA
Sep 05, 2022NETGEAR Employee Retired
Yes, its correct. On your GS728TXP, select the port where the printer is directly connected as the source port. Then, select another port on the GS728TXP as the destination port on the GS728TXP where a PC (with Wireshark installed in it) is directly connected. Enable IGMP snooping. Then, print a document via AirPrint from your iPhone. Run Wireshark while you print a document via AirPrint from your iPhone. Do the same steps with IGMP Snooping disabled.
You may want to also verify this to the NETGEAR Expert handling your support ticket number in order to be sure since he/she will be escalating it to the higher tier of NETGEAR Support to avoid errors.
DaneA
NETGEAR Community Team
cwagz
Sep 05, 2022Star
Thanks Dane - I got the traces uploaded and the L3 tech said he is working on it.
