MartinG's avatar
MartinG
Request Letter of Volatility XS716E
I need a Letter of Volatility for a Netgear XS716E 10G switch that I purchased.  I cannot find one in the downloads section for the switch.
-Martin
  • MartinG,
    Certificate of volatility is given only per request. I already sent it to you via pm.
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    Hi MartinG,
    Here is the certificate of volatility for your XS716E. No password needed. The link will expire after 48 hr period.
  • JohnC_V's avatar
    JohnC_V
    MartinG,
    I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
    • MartinG's avatar
      MartinG
      JohnCarloV,
      I just got back from vacation and the link has expired.  Would you please repost?
      Also, why not post these in the Support area of the Netgear webstie for each device as a matter of course, rather than making it a special request per-user?
      Thanks in advance!
      Martin
      • JohnC_V's avatar
        JohnC_V
        MartinG,
ProSupport for Business
